[Si...] Posted September 21, 2020 Share Posted September 21, 2020 How would I setup the Characteristic for this. See Attachment. Do I set up a TP Characteristic and toggle on MMC for the Primary Datum. I haven't seen this call out before. When I create my Char. I input the Feature and toggle MMC, then I input the Feature Datum to the Primary Spot and toggle MMC. I get default 0.000000. Is there another way to evaluate this data frame? Additionally, I have other drawings with 3 Datums at MMC also.Position MMB.png Link to comment https://qualityforum.zeiss.com/topic/14536-how-to-evaulate-position-mmc-to-datums-at-mmb/ Share on other sites More sharing options...
[SH...] Posted September 21, 2020 Share Posted September 21, 2020 Please sign in to view this quote. Your datum B is a bore??. I think this article can give you some sort of idea.. http://cmmquarterly.mbccmm.com/index.ph ... pso-part-2 Link to comment https://qualityforum.zeiss.com/topic/14536-how-to-evaulate-position-mmc-to-datums-at-mmb/#findComment-76390 Share on other sites More sharing options...
[Si...] Posted September 22, 2020 Author Share Posted September 22, 2020 Yes, In this example Datum B is a Bore. Link to comment https://qualityforum.zeiss.com/topic/14536-how-to-evaulate-position-mmc-to-datums-at-mmb/#findComment-76392 Share on other sites More sharing options...
