Cylinders vs. 3d Line
Many times, I've seen people post to use a 3d Line constructed from 2 circles instead of using a Cylinder. Somebody may have explained why but I honestly don't remember. Can anyone explain why?
Also, there is information in the cookbook that states that if a cylinder depth is less than it's diameter, a circle feature should be used instead of a cylinder. However, nowhere in ASME Y14.5, have I seen anything stating this practice should be done. All I ever see is that the entire axis of a cylinder should be considered in a position or other GD&T call outs. I understand there are applications where measuring a very short cylinder may not be practical but there are plenty of "depth less than diameter" applications where a cylinder could be used with reliable results. Plus, if I measure 2 circles to create a 3d Line, the length of line is not the full length of the cylinder.
https://qualityforum.zeiss.com/topic/14538-cylinders-vs-3d-line/
I think a lot of people do this from their old DMIS days. The 3d Line method is incorrect because the axis line is drawn from the center-point of the circles. The Cylinder/Cone/Step-Cylinder using all of the points to create the axis line is the correct method. This is why you will see differences in the A1/A2 when comparing a Cylinder that is created from all of the scanned points, and a 3d Line created only from the center-point of the circles.
This topic gets covered in AUKOM GD&T as there is great discussion regarding how ISO & ASME describe datum construction, and I know our trainer talked about doing this in Calypso.
https://qualityforum.zeiss.com/topic/14538-cylinders-vs-3d-line/#findComment-76396
I would assume that creating a 3d Line from 2 circles or creating a cylinder using 2 circle paths would be nearly the same. Length of 3d Line and length of cylinder axis would be the same. The difference would come with a cylinder extracted from a model measuring with 2 circle paths due to the extrapolated end points. However, if this was a datum feature, would it really matter as the axis is infinite. Obviously, the distance between the 2 circle paths affects the reliability of this axis.
https://qualityforum.zeiss.com/topic/14538-cylinders-vs-3d-line/#findComment-76400
Theoreticaly if cylinder is rather cone, then it will get another results for dimensions, but axis should be the same i think.
I wonder how it is for length and start point of this cylinders for calculations. ie. for 3d line it is fully defined by circles, but if you measure cylinder a few mm from edges, would it be shorter?
https://qualityforum.zeiss.com/topic/14538-cylinders-vs-3d-line/#findComment-76406
Least Squares evaluation:
Axis right in the center.
Feature points in 3D Line:
Axis 0.12mm below the center
Has to do with the point density/distribution on the surface.
All illustrations are the result of CALYPSO-calculations.
The surface points (surface geometry) are designed
by a CAD application.
Contribution_22_09_2020.xlsxContribution_15_09_2020.pdf
https://qualityforum.zeiss.com/topic/14538-cylinders-vs-3d-line/#findComment-76412
I don't think a 3D line between two circle and an axis per ASME Y14.5 is the same. Looks like depending on where the circles are scanned will affect where the center is calculated. Axis of a cylinder is the most accurate evaluation as some have already stated.
https://qualityforum.zeiss.com/topic/14538-cylinders-vs-3d-line/#findComment-76414
