PCM store results
Presettings
Part_Type = inquireList("Are you running a Set-up Part or full Production?","Set-up","Production")
selectCase Part_Type
case "Set-up"
setRecordHead("partid","Set-up")
case "Production"
setRecordHead("partid","Production")
endSelect
Postsettings
filePath = "T:\DMR\CMM Data\10122X Op-10_Rev_A\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt"
if fileExists(filePath) then // if it can't find the file then it will not error out.
endif
if Part_Type == "Set-up"
copyFile(filePath,"T:\DMR\CMM Data\10122X_Set-up\theresults.txt")
endif
When the operator chooses "Set-up" the report goes to the 10122X Set-up folder like it's supposed to.
It also goes to the filePath = "T:\DMR\CMM Data\10122X Op-10_Rev_A\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt". I don't want it to go there.
https://qualityforum.zeiss.com/topic/14554-pcm-store-results/
Put
FileEnd="10122X Op-10_Rev_A\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt"
In the production part of your inquire list
Put
FileEnd="10122X_Set-up\theresults.txt"
In the setup part of your inquire list
FileBase="T:\DMR\CMM Data\"
filePath =FileBase+FileEnd
https://qualityforum.zeiss.com/topic/14554-pcm-store-results/#findComment-76478
We had the same problem as you. We use that quite easy solution:
First you set the path, depending on the choice of the operator:
case "Set-up"
Path = "T:\DMR\CMM Data\10122X_Set-up\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt"
case "Production"
Path ="T:\DMR\CMM Data\10122X Op-10_Rev_A\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt"
endSelect
Then you define the path in "Name for output files"
Et voilà !
https://qualityforum.zeiss.com/topic/14554-pcm-store-results/#findComment-76482
