[To...] Posted September 16, 2020 Share Posted September 16, 2020 Hey guys, So I'm trying to measure flatness on one of the surfaces on a shaft. I'm using the loop characteristic to do it, which seems to be working, but i when I print the report, instead of giving me a single flatness value, it gives me 48 of them (that's the number I used to make a full 360 sweep of the surface, but just for trial and error, I currently have it set to 3). The highlighted surface is the one I'm looking to get a flatness measurement on. Any ideas? Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/ Share on other sites More sharing options...
[Ma...] Posted September 16, 2020 Share Posted September 16, 2020 I don't think that will work as a loop. It looks like you're trying to skip the holes? It might be that you have to copy the stratagy and then paste, but then change the start angle. Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76614 Share on other sites More sharing options...
[To...] Posted September 16, 2020 Author Share Posted September 16, 2020 Please sign in to view this quote. Exactly. I am looking to bypass the .06 reamed holes. So I copy the flatness characteristic multiple times to make a full 360? How do I make the flatness show up on the report as a single feature instead of it showing up on multiple lines? Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76616 Share on other sites More sharing options...
[Ma...] Posted September 16, 2020 Share Posted September 16, 2020 I don't think there is a shortcut for this I'm afraid, you'll just have to copy and paste and adjust the start angle in the circle path to the pitch you want.Untitled.jpg Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76618 Share on other sites More sharing options...
[Ma...] Posted September 16, 2020 Share Posted September 16, 2020 You could pattern Points and then Recall Feature Points into a Plane. That'll speed you up a bit. Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76620 Share on other sites More sharing options...
[SH...] Posted September 16, 2020 Share Posted September 16, 2020 Why you don't use ploy line or circular path like this??IMG_20200916_205708.jpg Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76622 Share on other sites More sharing options...
[To...] Posted September 16, 2020 Author Share Posted September 16, 2020 Please sign in to view this quote. I will try that. Now that I think about it, I can use two circle patterns and just have one of them go over the reamed holes, while using the fly scanning, to ignore them? Am I understand it correctly? Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76624 Share on other sites More sharing options...
[Ri...] Posted September 16, 2020 Share Posted September 16, 2020 If you have fly-scan, then use that. Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76626 Share on other sites More sharing options...
[SH...] Posted September 16, 2020 Share Posted September 16, 2020 Please sign in to view this quote. May I know why you are using 48 loops?, if I create a program like this definitely my QA manager will fire me.. Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76628 Share on other sites More sharing options...
[Ri...] Posted September 16, 2020 Share Posted September 16, 2020 If you don't want to do fly-scan, or don't have it. You can just pattern the feature, and recall the pattern into another feature. See the attached screenshots. Link to comment https://qualityforum.zeiss.com/topic/14580-measuring-flatness-on-a-round-surface/#findComment-76630 Share on other sites More sharing options...
