[Ri...] Posted September 11, 2020 Share Posted September 11, 2020 I'm using a double monitor setup on our CMM. Normally our (piweb) reports show up on the 2nd screen but since a few weeks they show up on the same screen as the calypso software. Any thoughts on how to fix reports to the second screen? Kind regards, Rik Link to comment https://qualityforum.zeiss.com/topic/14590-dual-screen-setup/ Share on other sites More sharing options...
[Da...] Posted September 11, 2020 Share Posted September 11, 2020 I just left clicked it and dragged to the other monitor and released it there. It worked for me. Link to comment https://qualityforum.zeiss.com/topic/14590-dual-screen-setup/#findComment-76662 Share on other sites More sharing options...
[Am...] Posted September 11, 2020 Share Posted September 11, 2020 On windows 10 if you drag something to the monitor you want it to open on, then half-minimize? (I think its called restore down, the button in between close and minimize and close itin that state without maximizing it. After that it should open on that monitor. Link to comment https://qualityforum.zeiss.com/topic/14590-dual-screen-setup/#findComment-76664 Share on other sites More sharing options...
[Ri...] Posted September 15, 2020 Author Share Posted September 15, 2020 Thanks, problem is solved now. The window was slightly overlapping the other monitor after dragging it in windowed mode. the ''half minimize'' trick did the job Kind regards, Rik Link to comment https://qualityforum.zeiss.com/topic/14590-dual-screen-setup/#findComment-76666 Share on other sites More sharing options...
