Profile of a surface
No freeform needed if the top plane was a plane. But it's not. First I thought it was a sphere. But it's a cylinder, since the top line in view F seems straight. Secondly, the radius of 274 doen't have an S in front of the R274. And thirdly: the symmetry doen't have a diameter symbol in front of the tolerance - as it would need if the tolerance zone for symmetry was a cylinder. So the symmetry call-out is just in one direction. From left to right in view A-A.
Since the top cylinder is a prismatic feature, I guess you can indeed have Calypso calculating the a surface profile of the top cylinder. Without the free form option.
And since you have to use a cylinder for the symmetry, I would measure the top as a cylinder, not as a free form. To answer the original post.
That symmetry is something else... The center of such a large radius THAT close to the centerline?! Almost impossible - even with the best CM in the world. I guess the engineer who wrote that on the print doesn't have too much hands-on experience on a CMM. I would get rid of the +/- 0.2 on the radius and getbrid of the symmetry. Then put a rectangle around the R274 and just have the surface profile.
That surface roughness line is sweet! Took a while before I understood what Rmr is. And before I knew how to configure the roughness tester properly.
And that R0.3 and R0.5... How you're gonna inspect that?!
To Mattias: Lycka till, kompis!
https://qualityforum.zeiss.com/topic/14596-profile-of-a-surface/#findComment-76760
