Running Newer Versions of Calypso
I wrote a program using offline seat of 2019 but realized the machine is still on 2018. I tried deleting the "version" file but 2018 still can't open the newer versions. Any ideas? Any thoughts on a way to avoid having to totally re-program the part?
Currently, upgrading machine is not an option.
Try the following steps
- make a copy of the inspection
- remane the inspection name inside the ..\username
- modify the revision inside the file ..\version
- delete all files containing actuals
- delete or rename the file ..\inspset
Open the copy with revison you need
- It could be possible reassign stylus inside the program
- Make test run with that version (Simulation)
- Store it
Test done by program created under CALYPSO 2020 reload by CALYPSO 2018
