Characteristic
Is there somewhere in Extra/Settings to make the nominal number in Characteristic what we need it to be? Example 5 degrees plus or minus 2 degrees will say it is 6 degrees in nominal and not let you change it without changing the feature to match up exact. The older versions of Calypso always let us make this nominal what we wanted it to be without matching the feature to it. This is an aggravation on every Characteristic but real bad on Angles. We are on Calypso 6.8.
