[Ri...] Posted August 6, 2020 Share Posted August 6, 2020 Please sign in to view this quote. Yes. Better would be the feature has to not be referenced by any feature, characteristic, or PCM code. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76956 Share on other sites More sharing options...
[Mi...] Posted August 6, 2020 Share Posted August 6, 2020 Please sign in to view this quote. Please sign in to view this quote. Here are two more reasons why Characteristics is my choice. It's nice to have options either way. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76958 Share on other sites More sharing options...
[SH...] Posted August 6, 2020 Share Posted August 6, 2020 First time ,I see a hundred rating 😮 Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76960 Share on other sites More sharing options...
[Da...] Posted August 6, 2020 Share Posted August 6, 2020 I don't see where running from the characteristic list can be anything but slower. As mentioned by others, you program the feature list so that the machine has less travel from 1 feature to the next. I program my characteristic list to that the report follows the drawing views so that you can follow. I do understand the original comment that when running from the feature list, the characteristic list does not populate until the program completes. But to me, this is minor to the run time saved. Remember, if you are looking for only certain characteristics to be reported, you can select those and only run what is needed, but still have the order of run from the feature listcalypso lists.png Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76962 Share on other sites More sharing options...
[Is...] Posted August 7, 2020 Share Posted August 7, 2020 Please sign in to view this quote. Actually, running from Characteristics is faster, but looks like is not popular to deal with the execution order using this list.Features vs Characteristics list.7z Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76964 Share on other sites More sharing options...
[Me...] Posted August 7, 2020 Share Posted August 7, 2020 So Israel, your saying this video is a physical run of a part. I need to bubble prints and report as such. Characteristics would be faster? Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76966 Share on other sites More sharing options...
[Is...] Posted August 7, 2020 Share Posted August 7, 2020 Please sign in to view this quote. Physical running or not is not relevant due to you can manipulate the execution order according to your needs (I must accept that from Characteristic list this is more difficult). However Characteristic list is faster because the software computes it faster. I will quote myself again: Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76968 Share on other sites More sharing options...
[Ke...] Posted August 7, 2020 Share Posted August 7, 2020 It sounds like the correct answer is "It depends" 🤣 Shorter programs that do not require multiple stylus systems and styli are likely to run faster using Characteristics, since (as Israel stated) the computation time is faster (I'm guessing that this is because, it is processing as it runs); whereas, longer programs (some of my larger programs take over an hour to run) are more likely to run faster using Features, as the time saved from probe changes exceeds the potential time saved via processing. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76970 Share on other sites More sharing options...
[Me...] Posted August 7, 2020 Share Posted August 7, 2020 Still don't see it. Again, since I bubble my dimensions, there is no way I could get my machine to run around constrained to the characteristics and report faster than via the feature run. I watched the video. Neither one of my machines can probe that fast. Israel, put up a video of the machine running and physically probing to show the time difference. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76972 Share on other sites More sharing options...
[Jo...] Posted August 7, 2020 Share Posted August 7, 2020 Please sign in to view this quote. This is "flat earth" territory here. I think most people program grouped by probe, and area of part. If you run in feature order ALL the required data is gathered and it computes the characteristics at the end. If you run in characteristics order it must run around the part to gather the required data "right now" per characteristic. The possible exception to this is Mini Plans Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76974 Share on other sites More sharing options...
[Me...] Posted August 7, 2020 Share Posted August 7, 2020 Thanks John. Oh no! Another round earth person. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76976 Share on other sites More sharing options...
[Is...] Posted August 9, 2020 Share Posted August 9, 2020 Please sign in to view this quote. naa, the mess you make with the machine movements can be optimised not depending of the execution list selected Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76978 Share on other sites More sharing options...
[Mi...] Posted August 11, 2020 Share Posted August 11, 2020 Please sign in to view this quote. Yes, if the part is still in-process. We may be able to re-cut it while the job is still set up, and re-inspect it afterwards. I can see an argument to be made for doing it either way. I'm just glad we are given an option. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76980 Share on other sites More sharing options...
[Er...] Posted August 11, 2020 Share Posted August 11, 2020 I would say running the program how it was programmed would be most efficient. If you build the program from Characteristics, it would mostly follow the order of the features and could be faster. If you build the program from features, running it from features list would be most efficient. I find it faster for me, to program from features personally, and then we run the program from features to optimize the run. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76982 Share on other sites More sharing options...
[Ja...] Posted August 12, 2020 Share Posted August 12, 2020 Please sign in to view this quote. Well put, Eric. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76984 Share on other sites More sharing options...
[Ma...] Posted September 10, 2020 Share Posted September 10, 2020 Can a characteristic be masked using PCM? eg. if Variable == true then maskCharacteristic("Hole 1") endif Obviously this isn't the correct code, but is there any commands that would work as such? Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76986 Share on other sites More sharing options...
[To...] Posted September 10, 2020 Share Posted September 10, 2020 I prefer to program by features by stylus, i.e. with -Z stylus active, I extract/create all of the features that I want o measure with it. I change to +Y stylus and extract/create all of the features, and so on. I group all of the features by stylus and then group those groups by stylus system.. And when I go into Features Settings Editor, the group names show up and make it easy for me to verify the correct stylus is in the right group. Or, when I am reviewing Clearance Planes. Below is an example of my system.program layout.jpgprogram layout2.jpgAnnotation 2020-09-10 082700.pngAnnotation 2020-09-10 082641.png Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76988 Share on other sites More sharing options...
[03...] Posted September 10, 2020 Share Posted September 10, 2020 Please sign in to view this quote. SAME! Look how organized that is.... if only every program I came across looked like this! 🤣 Although my end product looks the same as yours, I usually extract/create all of my features with no regard to the stylus I'm going to use, and then go and apply them afterwards in Measurement Plan Editor. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76990 Share on other sites More sharing options...
[To...] Posted September 10, 2020 Share Posted September 10, 2020 Please sign in to view this quote. Thanks. I should have stated, that if I am "disciplined", I pre-select the stylus before extracting the feature so the correct clearance plane will generally be selected but 9 times out of 10, I totally space out and forget about my stylus selection and have to correct it afterwards. Good practice to review those properties prior to first program execution anyhow. 😃 Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76992 Share on other sites More sharing options...
[Cl...] Posted September 10, 2020 Share Posted September 10, 2020 I bet you have all your canned goods in your cupboard organized by size and rotated with the labels facing out. 😃 Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76994 Share on other sites More sharing options...
[To...] Posted September 10, 2020 Share Posted September 10, 2020 Please sign in to view this quote. Are you serious? lol I'm 2 amazon boxes away from being on the next episode of "Hoarders"....LMAO Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76996 Share on other sites More sharing options...
[Cl...] Posted September 10, 2020 Share Posted September 10, 2020 🤣 What you are doing is absolutely the way to go. I created a "CMM Programing Best Practices" document that details exactly how a program is to be created down to the smallest of detail. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-76998 Share on other sites More sharing options...
[Sc...] Posted September 10, 2020 Share Posted September 10, 2020 Please sign in to view this quote. Clarke, Would you be willing to share your "CMM programming best practices" document either here or by PM? 🙂 Scott Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-77000 Share on other sites More sharing options...
[Cl...] Posted September 10, 2020 Share Posted September 10, 2020 Sure, I can't share the actual document, but I can share the contents. I'll sent it to you tomorrow. Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-77002 Share on other sites More sharing options...
[Ni...] Posted September 10, 2020 Share Posted September 10, 2020 I am new to programming and using CMMs but ever since seeing a program go back and forth to measure a part, I've decided it would be best to organize it and measure all the features that are next to each other. I have it so everything on X+ gets measure then it moves on and measures everything on Y- and so on. Especially with our longer parts. It hurts to see it travel back and forth. And since most of our parts require different probes, I organize them trough that as well. Imagine the head going to pick up one probe system to measure a plane and then going back to the rack to grab another probe system to measure another plane. 😱 Link to comment https://qualityforum.zeiss.com/topic/14630-programming-from-feature-or-characteristic-list/page/2/#findComment-77004 Share on other sites More sharing options...
