[Ro...] Posted September 10, 2020 Share Posted September 10, 2020 I was wondering if anyone knows if you can change the reporting output while using AutoRun. Currently, I am running 20-30 parts and PiWeb brings up a report after every part is inspected. Is there a way to have just one report compiled containing all of the parts in the inspection? Link to comment Share on other sites More sharing options...
[48...] Posted September 10, 2020 Share Posted September 10, 2020 Please sign in to view this quote. Hi Rob, You could use the TableProtocol, which will show you the last 12 results by default. You can also create your own report with X amount of samples depending on your usual sample size/inspection quantity. This would require some legwork to format the report the way you want to see it, but yes it is possible. As far as I know, you would change the report template for end of CNC run in the Multiple Report dialog box within the measurement plan. I don't know AutoRun very well and if there is a way to change it in there... Link to comment Share on other sites More sharing options...
