Z axis Depth.
Hello Everyone,
I have tried setting the Z axis depth but I'm not doing something correctly. It will start probing in directions I haven't touched off. Is there a way to set the Z axis depth when checking a bore or circle and still using the same probing points originally setup?
Thank you.
Go to your strategy and open the circle path, in the lower portion of that window you will see Start height, you can change the number in the box to move the circle up or down as you may need.
