Characteristics don't run in Calypso
Hello again,
I have been having an issue with a measurement plan not running through all characteristics. I have touched off on all of the features I need and setup the characteristics to measure using two different probes. I've setup my base alignment and clearance planes. But when I run the program it only runs one characteristic out of 18. Where did I go wrong? I ran into this once before but I can't remember what I did to fix this. Thank you.
When you hit run there is an option to run all characteristic or to run current selection, if it on current selection it will only run whatever you highlight in the program.
