[Br...] Posted September 2, 2020 Share Posted September 2, 2020 I'm able to load a step file and create features. Once the inspection file is saved and opened at a later date the step file is not present. I went back and opened some older inspection plans and the step file loads correctly. Any idea which setting I'm missing to cause this issue? Link to comment Share on other sites More sharing options...
[Sh...] Posted September 2, 2020 Share Posted September 2, 2020 I Hope someone can answer this as I am having the same issue. Link to comment Share on other sites More sharing options...
[Jo...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. My first guess would be the file path changed Link to comment Share on other sites More sharing options...
[To...] Posted September 2, 2020 Share Posted September 2, 2020 After you save the program for the first time, go to menu item View > Measurement Plan Directory and look for a file name model.sab. Whenever you load a model, it will convert the model to an .sab (standard acis binary) file. If it's there, it should be ok. Also, go to menu item File > CAD Load Settings. Make sure settings are like below. However, you're able to open other programs and see the model, so I don't think this is the problem. Annotation 2020-09-02 154958.jpgFetching info... Link to comment Share on other sites More sharing options...
[Br...] Posted September 2, 2020 Author Share Posted September 2, 2020 Yes, this fixed the issue. Not sure how it was changed. Everything is working now. Link to comment Share on other sites More sharing options...
