[Ni...] Posted September 2, 2020 Share Posted September 2, 2020 Hello, How would I create a compound datum/dash datum in calypso? I measured both diameters as cylinders and created a "3d line" that runs through both centers. The problem with that is that it won't let me do MMC on that 3d line when I use it as a datum. I tried using "parallel cylinders" which did let me do MMC but the software crashes when I use "parallel cylinders" Thank You,zeiss3.PNGzeiss2.png Link to comment https://qualityforum.zeiss.com/topic/14702-compound-datums-dash-datums/ Share on other sites More sharing options...
[Jo...] Posted September 2, 2020 Share Posted September 2, 2020 Post by Eric Moberg ยป Thu Aug 27, 2020 1:11 pm Creating a line between datum A and datum B and using that as a datum will not be correct. Use a step cylinder as datum since you have plenty of surface at the datums to work with. Link to comment https://qualityforum.zeiss.com/topic/14702-compound-datums-dash-datums/#findComment-77562 Share on other sites More sharing options...
[Jo...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. This was in another thread originally with an A-B Datum.. Link to comment https://qualityforum.zeiss.com/topic/14702-compound-datums-dash-datums/#findComment-77564 Share on other sites More sharing options...
[Ma...] Posted September 2, 2020 Share Posted September 2, 2020 But Eric is right. MMC is used for measured element but not for datums, which in 3dline can not be used. But i didn't see step cylinder. It exists? I'll have to look Link to comment https://qualityforum.zeiss.com/topic/14702-compound-datums-dash-datums/#findComment-77566 Share on other sites More sharing options...
[4a...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. Features drop down > Special Geometries > Step Cylinder is where you will find that. ๐ Link to comment https://qualityforum.zeiss.com/topic/14702-compound-datums-dash-datums/#findComment-77568 Share on other sites More sharing options...
[Ni...] Posted September 2, 2020 Author Share Posted September 2, 2020 Please sign in to view this quote. Please sign in to view this quote. I created a step cylinder and used recall feature points, picked Datum B and datum D, to create my B-D Datum. I am now able to apply MMC on that B-D datum. Thanks a lot! ๐ฎ Link to comment https://qualityforum.zeiss.com/topic/14702-compound-datums-dash-datums/#findComment-77570 Share on other sites More sharing options...
