[Ia...] Posted September 1, 2020 Share Posted September 1, 2020 I need to get the "Y" values of these intersections from where an OD meets a line. I do not have access to curve or freeform. Edgepoint doesn't seem to work on these. Has anyone had to deal with something like this before? All intersections and projections I've tried just don't seem to work. Hoping I'm just having a big brain fart. Link to comment Share on other sites More sharing options...
[Ch...] Posted September 1, 2020 Share Posted September 1, 2020 Measure Cylinder, measure 2D Line, Intersection ? Link to comment Share on other sites More sharing options...
[Jo...] Posted September 1, 2020 Share Posted September 1, 2020 Please sign in to view this quote. If you tried this method and still is finicky, try projecting both components onto a plane so they will intersect. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 1, 2020 Share Posted September 1, 2020 You can also measure it as a curve, and use the Kink Point. It works well for things like this. Link to comment Share on other sites More sharing options...
[Er...] Posted September 1, 2020 Share Posted September 1, 2020 Please sign in to view this quote. Aint that easy if he doesnt have curve. It will be hard to anyone to give you an answer based on your question. Because "y-value" is pretty vauge. What accuracy of the coordinate do you need? But a picture is always better then words. Link to comment Share on other sites More sharing options...
