Characteristic result variation
Hi, I have a part where I have measured a plane ( normal to X & Y axis ) and a single point in the Z axis. When I go to characteristics to find a distance from the plane to the point I get a value of .0460, but if I go from the point to the plane I get .0446. Why the different values when I am using the same two features just switching which is specified first?
Calypso software.
https://qualityforum.zeiss.com/topic/14742-characteristic-result-variation/
Im gonna take a guess and i think its due to the alignment. Which distance characteristic are you using? The plane is going to read from the center of the plane, doing it one way might be using the plane as the reference thus the measurement is from center of plane perpendicular to plane up to that height, and the other might be a straight distance from plane center to point.
This is like Tom said - 2nd is datum reference - so if it's a point then axis are given by real touch direction. But i don't have it tested on points touched on chamfers and angled planes. Theoreticaly it can give good results, but just interpolated by deviations of nominal and actual a1 ,a2.
But almost everything can be simulated with theoretical features.
