[La...] Posted August 27, 2020 Share Posted August 27, 2020 I am having trouble with the Cumulative Radial Runout below. I've never had to deal with Runout much, so I am not sure what I need to do on this. They indicate it in the lathe at about .0005". I thank you in advance for help! Link to comment Share on other sites More sharing options...
[SH...] Posted August 27, 2020 Share Posted August 27, 2020 Measure datum a and b as cylinder with high density (scanning). For first runout create a 3D line using two cylinders, calculate runout with respect to it. Second case calculate with respect to datum A cylinder. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 27, 2020 Share Posted August 27, 2020 To add, you need to probe/scan the entire surface of both OD cylinders. In addition A-B is one datum from two, if you weren't aware. Link to comment Share on other sites More sharing options...
[Er...] Posted August 27, 2020 Share Posted August 27, 2020 Creating a line between datum A and datum B and using that as a datum will not be correct. Use a step cylinder as datum since you have plenty of surface at the datums to work with. Link to comment Share on other sites More sharing options...
[An...] Posted August 28, 2020 Share Posted August 28, 2020 Exceeding the limits of CMM. See attached.Contribution_28_08_2020_c.xlsx Link to comment Share on other sites More sharing options...
