deviation illustrations
One thing I'm not very good at in Calypso is "illustrating" the problems with a part to a machinist so the can make a correction. I know I've seen some pretty cool graphics showing, say, a free form surface with its deviations exaggerated, like in the attached. How do you make these? I've tried messing around with Graphics Elements and a few other features, but they're pretty... unintuitive. Can someone point me in the right direction?
https://qualityforum.zeiss.com/topic/14768-deviation-illustrations/
I guess part of the problem is the version I'm running 5.4. I should have mentioned that earlier.
A tutorial I just found shows the evaluation windows having a "results" tab; mine has an "actuals" tab in its place, and no "display" box to check.
Do older versions just not have the same functionality?
5.4 should be fine, i am almost certain that when we bought this machine 7-8 years ago it had 5.4 in it, and ive been doing profile plots since the first program i wrote at this job.
I think 'actual' means the same thing as 'result'.
I like cylinders at .010 inch and 50x scale personally.
(Note anything past this place does not help anything, its just me being a whiny baby)
Another case where PCD does something better than Calypso. In PCD the arrows are always visible, they are never hidden behind cad model skin. even adjacent surfaces that don't have anything to do with the profile are transparent, calypso only allows you to see thru the skins being evaluated, so im forced into wireframe views that can be confusing when printed out. in calypso if you have a minus material condition and the cad model active, you cant see the deviation, you can only see the deviation of heavy material condition because its above the skin.
