[Lo...] Posted August 25, 2020 Share Posted August 25, 2020 Hello everyone, When I open a CAD model in Calypso and try to touch off a feature, it does not display on the model. Do I need to turn something off or on to make this visible? Thank you, Lou Link to comment Share on other sites More sharing options...
[52...] Posted August 25, 2020 Share Posted August 25, 2020 Once your part is aligned, you can go to CAD > Cad Model Control > Show probing object. You could turn it on before the part is aligned, but your probe will be out in space relative to the part. Link to comment Share on other sites More sharing options...
[Lo...] Posted August 25, 2020 Author Share Posted August 25, 2020 Please sign in to view this quote. Thank you Laura, Even when I have it aligned I can see the probe, but everything is real far apart from the coordinates and my features are way out in space to the point where I can't see them. Link to comment Share on other sites More sharing options...
[Ma...] Posted August 26, 2020 Share Posted August 26, 2020 You have to manually probe alignment ( Start or Base ) for get Calypso know where is a part. I had this even when i loaded saved alignment and part didn't fit there exactly ( another angle, missplacement ). Then were even measured points out of model -> problems with recall measured points - not within select box. Link to comment Share on other sites More sharing options...
