[Ke...] Posted August 18, 2020 Share Posted August 18, 2020 I have seen from previous post that some newer versions of calypso have the ability to create backups for Probe Files , Probe Racks and other key features. But we are running 5.6 and 5.8 and getting new pc to go from 7 to 10. Does anyone have a way of transferring all ( about 400+) probe files other then exporting them individually. Then bring them 1 by 1 into the fresh install?? Link to comment Share on other sites More sharing options...
[SH...] Posted August 19, 2020 Share Posted August 19, 2020 Please sign in to view this quote. 400 probe files, wow quite long,anyway you can create a backup for all stylus system by a PCf file. Transfer to other system using USB drive. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 19, 2020 Share Posted August 19, 2020 Please sign in to view this quote. If you copy the config folder from inside of the C:\Users\Public\Public Documents\Zeiss\Calypso folder this will retain your machine tab, so all of your probes will be brought over. Link to comment Share on other sites More sharing options...
[SH...] Posted August 19, 2020 Share Posted August 19, 2020 Don't forget to copy your license file that is very very important, it may be hide .... Link to comment Share on other sites More sharing options...
[Ri...] Posted August 19, 2020 Share Posted August 19, 2020 Please sign in to view this quote. If you have a dongle, it is located within C:\ProgramData\Zeiss\License Link to comment Share on other sites More sharing options...
[Ma...] Posted August 19, 2020 Share Posted August 19, 2020 Didn't ZEISS created pre_install exactly for this purpose? I think it transfer all for new instalation. Link to comment Share on other sites More sharing options...
[Ke...] Posted August 19, 2020 Author Share Posted August 19, 2020 We are using the PCF export method right now for the first Zeiss. But you have to do every probe individually, or do you know a way to do a batch Export? We are going to try upload the original calypso Probe files and SQL thanks for the ideas. Link to comment Share on other sites More sharing options...
[b7...] Posted August 19, 2020 Share Posted August 19, 2020 Please sign in to view this quote. In newer versions of Calypso there is a backup tool under Extras > Settings > Miscellaneous > Maintenance. But that came out in 6.0, I believe. Link to comment Share on other sites More sharing options...
[Ke...] Posted August 19, 2020 Author Share Posted August 19, 2020 Please sign in to view this quote. This option is not available in 5.6 or 5.8 (2014). Link to comment Share on other sites More sharing options...
[Gr...] Posted August 19, 2020 Share Posted August 19, 2020 Here is a Moving Software procedure that Zeiss sent me when we got a new computer. It should explain everything you need to do Greg Kozera Link to comment Share on other sites More sharing options...
[To...] Posted August 19, 2020 Share Posted August 19, 2020 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[Ke...] Posted August 25, 2020 Author Share Posted August 25, 2020 It took a few tries this weekend but we finally got the probe files transfered. Thanks for everyone's help with this process. Copying only the Config file did the trick. Link to comment Share on other sites More sharing options...
