Editing cycle time
You mean in simulation? If that's the case it will only display the correct runtime if you actually measure a part.
For instance, the part in the photo I attached takes 30 mins to actually run, but in simulation it takes less than a minute.
If there is a way to display actual runtime without measuring a real part, I'm unaware of it.
https://qualityforum.zeiss.com/topic/14794-editing-cycle-time/#findComment-78404
I have an irritating customer always ask more reports so what we do that we check few jobs and create more report by editing, but I can't edit the measuring time it shows zero after running the program only, and customer asking why the cycle time is zero. And it became a nightmare for us to debate with customer.
Simple words customer satisfaction
https://qualityforum.zeiss.com/topic/14794-editing-cycle-time/#findComment-78410
I'm pretty sure you can remove the runtime from the report if you edit the template from that program. But I would try to either talk the customer out of needing more reports or actually measure the parts as required by the customer that is paying you to do so. Dangerous road sending out reports with false data to customers and probably illegal.
https://qualityforum.zeiss.com/topic/14794-editing-cycle-time/#findComment-78412
Either use your own template or edit your pdf.
Why is it important that your customer knows the cycle time?
I would not let our customers know our cycle time. Cause if I could reduce the cycle time they would want reduced price of the part.
Let them know the hard facts partid, measurement results and evaluation.
https://qualityforum.zeiss.com/topic/14794-editing-cycle-time/#findComment-78420
Customer is satisfied with our product,he is planning to give us more orders,please understand.
we have only one CMM and it is impossible for us to run according to customer advice ,it will affect other production planning.
Please don't judge a book by its cover..
https://qualityforum.zeiss.com/topic/14794-editing-cycle-time/#findComment-78428
I would still change the template so that the header had less info and when they ask why. Just tell them that you have kept what is most critical in terms of traceability and evidens that parts are OK.
I can understand why they would be suspicious if the only thing that is missing from former report is cycle. But change a couple of other things aswell then.
https://qualityforum.zeiss.com/topic/14794-editing-cycle-time/#findComment-78446
