[ad...] Posted August 21, 2020 Share Posted August 21, 2020 Hi All, I am getting news of a persistent error from our CMM operators, in the status box a error chip message appears as it try's to re-rack and we have to close Fac's to correct the error meaning time spent. My suggestion is it caused by static as it enters the pocket? has anyone found any solutions to rectify this issue? Best Regards Adam Link to comment Share on other sites More sharing options...
[Da...] Posted August 21, 2020 Share Posted August 21, 2020 I only use ten plates, and they're all manual load so, I just turned off the chip ID. You're probably in a different situation. The machine still knows which probe goes with which program. Link to comment Share on other sites More sharing options...
[Ch...] Posted August 21, 2020 Share Posted August 21, 2020 I agree with Dave. I wouldn't use the ID Scanner unless I absolutely had too. In my opinion, the best way to use the Chip ID function is to not use it. Link to comment Share on other sites More sharing options...
[Mi...] Posted August 21, 2020 Share Posted August 21, 2020 Please sign in to view this quote. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Exactly! 🤣 Link to comment Share on other sites More sharing options...
[To...] Posted August 21, 2020 Share Posted August 21, 2020 Please sign in to view this quote. Are you saying with Stylus ID turned off, it will know if you have loaded the wrong stylus system? Link to comment Share on other sites More sharing options...
[Da...] Posted August 21, 2020 Share Posted August 21, 2020 Please sign in to view this quote. It only knows by rack assignment. If someone puts a 2x70 where a 1x41 is supposed to be it will crash into the part. We have the ID turned off and an operator changed out a probe and forgot to reset the rack. Link to comment Share on other sites More sharing options...
[To...] Posted August 21, 2020 Share Posted August 21, 2020 Please sign in to view this quote. That is what I have always believed but Dave's comment sorta sounded like "the machine knows" and my BS detector was going off...LOL Link to comment Share on other sites More sharing options...
[Da...] Posted August 21, 2020 Share Posted August 21, 2020 So if you start a program with the wrong probe inserted it will prompt you to change it. If you manage to insert the WRONG probe, you're on your own... And headed for a crash. So KIND of knows 😃 Link to comment Share on other sites More sharing options...
[Da...] Posted August 22, 2020 Share Posted August 22, 2020 If it’s XXT you are using I advise a contact cleaner on the contacts on the plate. I used to have this issue lots (still get it intermittently) but a contact cleaner like Deoxit and a wipe with a clean lint free after helps. Link to comment Share on other sites More sharing options...
[Vi...] Posted August 23, 2020 Share Posted August 23, 2020 I agree with Dave and Chad. "the best way to use the Chip ID function is to not use it" 🤣 Link to comment Share on other sites More sharing options...
