[Mi...] Posted August 18, 2020 Share Posted August 18, 2020 Never seen one like this. What are they asking for with this? TP with an UZ>> Kinda scratching my head lol Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/ Share on other sites More sharing options...
[Ri...] Posted August 18, 2020 Share Posted August 18, 2020 Sounds like someone was lazy and didn't want to just change the basic dimension... Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78704 Share on other sites More sharing options...
[Da...] Posted August 18, 2020 Share Posted August 18, 2020 Looks like it should be a profile. Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78706 Share on other sites More sharing options...
[Ma...] Posted August 18, 2020 Share Posted August 18, 2020 It's like 3,1 Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78708 Share on other sites More sharing options...
[Da...] Posted August 20, 2020 Share Posted August 20, 2020 There can’t be unequally distributed tolerance zones for positions. It should be a profile, like David said. It it were a profile, the UZ states that the center line of the profile is shifted -0.05 mm (into the material), the tolerance zone is 0.1 mm wide. So, the center line of the profile would be at 3.15 mm from the datum, and the allowed deviation would be from 3.1 to 3.2. Note that UZ works not the same way as the U modifier in ASME standard. The distances are local distances from the global datum to the local profile, not local two-point measurements. Still, since that’s an obviously flawed call-out, you should contact the designer. Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78710 Share on other sites More sharing options...
[An...] Posted August 20, 2020 Share Posted August 20, 2020 Please sign in to view this quote. Also the ASME-people seem to be lazy. See attached.Pic_8-1_b.jpg Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78712 Share on other sites More sharing options...
[Da...] Posted August 20, 2020 Share Posted August 20, 2020 Please sign in to view this quote. This is just to show how the tolerance should be called out. Unequally, with all of it being at or above the surface. Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78714 Share on other sites More sharing options...
[Da...] Posted August 20, 2020 Share Posted August 20, 2020 Some of us are still waiting Mike to get us info of standard used. Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78716 Share on other sites More sharing options...
[Ri...] Posted August 20, 2020 Share Posted August 20, 2020 Please sign in to view this quote. Profile tolerances in general are mostly lazy. Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78718 Share on other sites More sharing options...
[An...] Posted August 20, 2020 Share Posted August 20, 2020 Please sign in to view this quote. DIN EN ISO 14405 Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78720 Share on other sites More sharing options...
[Mi...] Posted August 20, 2020 Author Share Posted August 20, 2020 Imagine that... That took that crap off the latest Rev level. SO looks like I don't have to fool with it. I asked how this can be in the same FFC as a TP callout weeks ago. I got crickets ughh 🙄 🙄 So back to Defcon 5. Its been wiped. Who knows what they will come up with next ❓ ❓ ❓ Thanks All Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78722 Share on other sites More sharing options...
[Ri...] Posted August 20, 2020 Share Posted August 20, 2020 You can make whatever FCF you want with no repercussions. Link to comment https://qualityforum.zeiss.com/topic/14826-uz-callout/#findComment-78724 Share on other sites More sharing options...
