combining PiWeb reports??
Is there a way to measure a part on one side, flip it over and measure other features that are otherwise inaccessible and put all results in one report?
Actually, a better approach might be doubling the model and run it in one program. There are several ppl on here that can help with that instruction.
I have experience, that when you measure common ( general? ) surface and selecting on CAD model, then it not works.
At least i tried 2 models on same position ( but a few planes was moved ) then it was reporting nonsence numbers.
Normal exported features will work, but not for surfaces.
viewtopic.php?f=13&t=1964&p=12387&hilit ... art#p12387
viewtopic.php?f=13&t=1705&p=10896&hilit ... art#p10896
Search for "flip part" and there are a few threads about the subject.
I have a few programs that I stop in the middle and flip the part over so it is totally possible. I'm busy right so not much time to explain but I think these threads will get you going.
Not yet, but if i would have this case, i would prepare new fixture insert second model rotated into a program and prepare new safe alignment ( searching like 20mm before and 20 after point )
