[Mi...] Posted October 18, 2022 Share Posted October 18, 2022 Hello all , Is it possible to create a dynamic dialog? The number of widgets (columns and rows) depends on the user (project)? Defined by "gom.script.sys.create_user_defined_dialog" only allows to enter a specific number of items, eg checkbox. Is it possible to edit the dialog window content after its definition (adding more widgets, editing the number of columns and rows) - change the dialog box format? Link to comment Share on other sites More sharing options...
[Th...] Posted October 19, 2022 Share Posted October 19, 2022 It's possible. For general information about dialog handling (dynamic and static) please have a look at: https://connect.gom.com/x/DZ-VAg You must define the dialog with parameter "Extendable break dialog" to enable dynamic behavior by the dialog-event-handler. This code just shows a simple example for reference: import gom DIALOG=gom.script.sys.create_user_defined_dialog (content='<dialog>' \ ' <title>Test Dialog</title>' \ ' <style></style>' \ ' <control id="OkCancel"/>' \ ' <position></position>' \ ' <embedding></embedding>' \ ' <sizemode></sizemode>' \ ' <size width="198" height="191"/>' \ ' <content columns="1" rows="4">' \ ' <widget columnspan="1" type="input::checkbox" rowspan="1" row="0" column="0">' \ ' <name>checkbox1</name>' \ ' <tooltip></tooltip>' \ ' <value>true</value>' \ ' <title>Checkbox 1</title>' \ ' </widget>' \ ' <widget columnspan="1" type="input::checkbox" rowspan="1" row="1" column="0">' \ ' <name>checkbox2</name>' \ ' <tooltip></tooltip>' \ ' <value>true</value>' \ ' <title>Checkbox 2</title>' \ ' </widget>' \ ' <widget columnspan="1" type="label" rowspan="1" row="2" column="0">' \ ' <name>text1</name>' \ ' <tooltip></tooltip>' \ ' <text>Text 1</text>' \ ' <word_wrap>false</word_wrap>' \ ' </widget>' \ ' <widget columnspan="1" type="input::string" rowspan="1" row="3" column="0">' \ ' <name>text2</name>' \ ' <tooltip></tooltip>' \ ' <value>Text 2</value>' \ ' <read_only>false</read_only>' \ ' <password>false</password>' \ ' </widget>' \ ' </content>' \ '</dialog>') # # Event handler function called if anything happens inside of the dialog # def dialog_event_handler (widget): DIALOG.text1.visible = DIALOG.checkbox1.value DIALOG.text2.enabled = DIALOG.checkbox2.value DIALOG.handler = dialog_event_handler RESULT=gom.script.sys.show_user_defined_dialog (dialog=DIALOG) For more information about every single dialog widget you can also use the Python-__doc__-shortcut. Link to comment Share on other sites More sharing options...
