Position label problem
Hello,
I am having a problem with position label naming.
As a example I choose simple distance and want to measure in X-direction. I will name dimensions as a Dim 3.
I do the measurement and send data to QC-Calc. QC-Calc reads data.
In QC-Calc end why there is _X at the end of the position name (Dim 3_X)? In Calypso is a there setting for position naming for using only typed position name?
When you use simple distance, it automatically adds the label because it has to be able to identify which of 6 options can be selected. Try using a cartesian distance instead.
