[Te...] Posted August 18, 2020 Share Posted August 18, 2020 Hello, I am having a problem with position label naming. As a example I choose simple distance and want to measure in X-direction. I will name dimensions as a Dim 3. I do the measurement and send data to QC-Calc. QC-Calc reads data. In QC-Calc end why there is _X at the end of the position name (Dim 3_X)? In Calypso is a there setting for position naming for using only typed position name?Simple distance.GIFQC-Calc.GIF Link to comment Share on other sites More sharing options...
[To...] Posted August 18, 2020 Share Posted August 18, 2020 Please sign in to view this quote. When you use simple distance, it automatically adds the label because it has to be able to identify which of 6 options can be selected. Try using a cartesian distance instead. Link to comment Share on other sites More sharing options...
[Er...] Posted August 18, 2020 Share Posted August 18, 2020 Nope, this is per software design. But in Calypso 2020 (7.0) you are able to set different names. Link to comment Share on other sites More sharing options...
[Ch...] Posted August 18, 2020 Share Posted August 18, 2020 Eric, What about renaming the components of a bore pattern? Instead of 'Bore_Pattern^1' Link to comment Share on other sites More sharing options...
[Ma...] Posted August 18, 2020 Share Posted August 18, 2020 Hide and mark char. ( mark with PiWeb ) and use UserFormula ( or how it is named 😃 ) Link to comment Share on other sites More sharing options...
