What is the source of the ACIS SOCKET FAILED error?
I'm attempting to run a program on the offline seat workstation (a simulation) and I seem to be getting the ACIS SOCKET FAILED error.
This only occurs when I go and do a manual allignment and I attempt to pick up the points on the top surface/ID. The odd thing is that I already ran the program on the PRISMO without any crashes and errors so I'm not quite sure why I am running into issues while attempting a simulation.
Thanks,
Tomas
On the offline seat I have a Quadro P2000 so I assume it is not the graphics card. I will go ahead and disable the firewall and see if this solves the issue.
Thank you for your help,
Tomas
  • 1 year later...
