Individual or Pattern?
Would datum B, in this instance, be the individual hole, or the pattern? The leader line is pointing to the individual, but "8x" is mentioned in the callout. If it IS the individual, that will clock my alignment to that hole, which doesn't make much sense given the other callouts on the print. Thank you everyone!
https://qualityforum.zeiss.com/topic/14924-individual-or-pattern/
