[Me...] Posted August 10, 2020 Share Posted August 10, 2020 Hello, I'm having troubles measuring a gap (see photos). I tried a contour trace but measurements are off by +0.5~1.0mm. I then tried using a videoscope but my measurements were off just as much but on the negative (-) side. How would you measure the gap? Thanks in advanced.08102020-2.jpg08102020-1.jpg Link to comment Share on other sites More sharing options...
[Ro...] Posted August 10, 2020 Share Posted August 10, 2020 Remove screw, insert gage pin? Link to comment Share on other sites More sharing options...
[Me...] Posted August 10, 2020 Author Share Posted August 10, 2020 Unfortunately my engineer does not want these to be unassembled. Link to comment Share on other sites More sharing options...
[Ro...] Posted August 10, 2020 Share Posted August 10, 2020 A bernz-o-matic propane torch & vise will allow you to bend a pin like a feeler gage. ZZ Pins are cheap. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 11, 2020 Share Posted August 11, 2020 Repro-rubber. Works great for stuff like this. There are several types. We use one that is a bb size plastic type material, that when heated up with a little water, becomes malleable enough to take the shape of anything. When it hardens, remove and measure it. Link to comment Share on other sites More sharing options...
