[Jo...] Posted August 10, 2020 Share Posted August 10, 2020 Can someone expound upon the input parameters for Flatness Ref Characteristic ? The print requirement is .013 mm per 25 mm. I used the 25mm for length 1 and length 2.. So now there is a choice of overlap, reference each plane/zone, and limit angle. Link to comment https://qualityforum.zeiss.com/topic/14944-flatness-ref/ Share on other sites More sharing options...
[Ch...] Posted August 10, 2020 Share Posted August 10, 2020 I use a 50% overlap. It basically takes the square and overlaps that surface area by 50%. I know that explanation sucks and I'll try to make a picture if I can get a minute. Link to comment https://qualityforum.zeiss.com/topic/14944-flatness-ref/#findComment-79570 Share on other sites More sharing options...
[Jo...] Posted August 10, 2020 Author Share Posted August 10, 2020 Please sign in to view this quote. Well, that's explanation is worth something, it's experience. So 50% overlap should cover all the iterations of that distance requirement ? I am only interested in in reporting the worst zone. The feature has a total flatness and this refinement. Link to comment https://qualityforum.zeiss.com/topic/14944-flatness-ref/#findComment-79572 Share on other sites More sharing options...
[Ch...] Posted August 10, 2020 Share Posted August 10, 2020 I think this will report what you are looking for. We use this to detect leak conditions caused by sudden jumps in flatness. Almost like a kink point. Link to comment https://qualityforum.zeiss.com/topic/14944-flatness-ref/#findComment-79574 Share on other sites More sharing options...
[Jo...] Posted August 10, 2020 Author Share Posted August 10, 2020 Please sign in to view this quote. Similar deal. It is a high pressure flange that has critical zones of leak path. Tool marks are not permitted to be continuous. This would also detect a mill step from multiple passes. Total flatness callout is generous, but the refinement really is the challenge. Link to comment https://qualityforum.zeiss.com/topic/14944-flatness-ref/#findComment-79576 Share on other sites More sharing options...
