Can't create a circle
CAD - Creating Features - Creation. I change to wireframe, click on the
wire circle and when I try to create the circle, I get this error message.
FYI, the ACIS Interface window is open?
You might try rebooting everything while slamming the mouse on the desk 5 or 6 times and cussing, lot's of cussing.Seriously, it's worked before. 🤣
Some models are picky when it comes to the selection of certain features. I think it depends on how the specific area was created and what type of edge was created in the process. Even CAD programs sometimes refuse to perform certain operations unless you change the way in which you create a feature. Recently I tried to add a simple edge radius to a model consisting of several boolean-united cuboids. --> Not possible. Only after uniting them in a different order, it worked. One would that shouldn't matter, but it did. Healing probably won't cure that kind of issue.
This is just one of those Calypso mysteries. What happens if you open a new program use that same model and then try it?
I've had weird errors where whatever is wrong is fixed and Calypso refuses to go back to working right on that program.
