[Ca...] Posted August 6, 2020 Share Posted August 6, 2020 I'm still in the process of transitioning to PiWeb full time. I've just noticed that Text aren't appearing in the PiWeb Standard Protocol printouts. How can I get these to display? Link to comment Share on other sites More sharing options...
[Ma...] Posted August 6, 2020 Share Posted August 6, 2020 Try searching in PiWeb section of forum. I solved it with creating plan-specific protocol. Link to comment Share on other sites More sharing options...
[No...] Posted August 6, 2020 Share Posted August 6, 2020 viewtopic.php?f=14&t=79 Link to comment Share on other sites More sharing options...
[Ca...] Posted August 6, 2020 Author Share Posted August 6, 2020 Thanks guys. Looks like I'll have to use result elements, or make permanent text boxes in the printout header. Link to comment Share on other sites More sharing options...
[c0...] Posted August 6, 2020 Share Posted August 6, 2020 What are you trying to do with text element? Group names? I've found that is the most common use of text element when dealing with our customers. Or, they want to leave a particular note about an item where you could use the comment field. I've done a few 'workarounds' to get around TextElement usage. If you have something specific I'm happy to help. Link to comment Share on other sites More sharing options...
[Ca...] Posted August 6, 2020 Author Share Posted August 6, 2020 In this instance, I was adding references to Engineering Change Orders to printouts. Some of our parts have several ECO's incorporated into the current drawing, and they have to be referenced in the printout. I used Text Elements for that. I'm leaning toward reworking the layout of the printouts header, and creating a few user input fields that can be left blank if unneeded. Link to comment Share on other sites More sharing options...
