Horizontal probing questions.
Hello everyone,
I am a complete rookie with this CMM , but learning in a hurry. I'm using an Accura with a Vast XT head. I am trying to probe a horizontal tube with several bore diameters and steps as well as features on top of the part. But when I am using horizontal probes, number 5 and 3. The probes travel straight down on top of the tube instead of traveling -X and then traveling in on +X to measure the diameters and steps. I have set my clearance planes pretty far apart on both -X and +X but I am not sure what I am missing. Thank you for any assistance.
Lou
You have to select the clearance group to be x- or x+ it sounds like its trying to come in from +z and it doesn't matter how far your clearance plane is it will keep doing that until you change that feature to x-. Easiest way is to open the feature and change it right there in the top left side.
