[Me...] Posted December 16, 2019 Share Posted December 16, 2019 Hello everyone, I'm looking for the PCM syntax. The instruction set should be complete. All commands are not described in the ZEISS user information for CALYPSO-PCM. Who can help me? // Winfried Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/ Share on other sites More sharing options...
[Is...] Posted January 14, 2020 Share Posted January 14, 2020 ... Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80236 Share on other sites More sharing options...
[Me...] Posted January 21, 2020 Author Share Posted January 21, 2020 Yes, I am of the same opinion, the ZEISS instructions are not good, regarding of all variables. That is my problem at the moment ! Thank you for your list. Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80238 Share on other sites More sharing options...
[Gu...] Posted July 25, 2020 Share Posted July 25, 2020 Please note: All official PCM commands can be found in the operating instructions If unofficial commands are used, errors, measurement errors and, in the most critical case, damage to the system can occur. If commands are missing or additional PCM functions are required, describe the request and use "My Voice" in the portal. https://portal.zeiss.com/my-voice Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80240 Share on other sites More sharing options...
[Ro...] Posted July 30, 2020 Share Posted July 30, 2020 I didnt even know Calypso had manuals, this could have been helpful a time or 2. C:\Program Files (x86)\Zeiss\CALYPSO X.X\userinfo\manuals\en The X.X will change depending on what version of calypso you have, then look for the PCM file. I don't think this is exactly what you are looking for, but its more than nothing. Credit Richard Shoemaker for posting this in the main Calypso forum. So, what are you trying to do? Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80242 Share on other sites More sharing options...
[Ri...] Posted July 30, 2020 Share Posted July 30, 2020 Please sign in to view this quote. The help has a few good topics that are extremely useful. I taught myself how to calibrate and use the RT from the help menu. Lol. Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80244 Share on other sites More sharing options...
[Cl...] Posted July 30, 2020 Share Posted July 30, 2020 Just curious, is your rotary laying in XY on a bridge CMM. I have several O-inspects, and one of them has a rotary, in ZX. It's qualified with an 8mm tooling ball, set at 45 deg. It rotates in 30 deg increments as it is probed with 6 points. Is yours qualified the same way? Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80246 Share on other sites More sharing options...
[Ri...] Posted July 30, 2020 Share Posted July 30, 2020 Please sign in to view this quote. Are you talking to me? That is typical for the O-Inspect. It is different than the ones found on bridge machines (yes, they are in the X/Y plane). The two most accepted ways to qualify your RT axis for a bridge CMM is the two sphere method (a sphere towards the bottom of the face plate, and one up at the highest Z point you will be measuring), and the cylinder method (a cylinder that is as tall as your tallest workpiece that you will be measuring) Link to comment https://qualityforum.zeiss.com/topic/15016-pcm-syntax/#findComment-80248 Share on other sites More sharing options...
