[To...] Posted July 30, 2020 Share Posted July 30, 2020 I am scanning 2 paths on a group of 3 surfaces. When I view the Profile to ABC, only 1 path appears. I created a copy of the profile and set it to the BA and both paths are showing. A little pre-story. I created the curve path from a section cut and then I copied the Point Set. I reversed the direction of the 2nd point set and altered the Z value to a lower position. Then, I edited the Z value of the 1st point set to create more coverage. The only reason I am mentioning this is that the profile to the DRF, appears to be showing the original path but the profile to the BA, shows the current paths. It's tough to see from pictures but the single path is not in the same place as either of the double paths. . . Link to comment Share on other sites More sharing options...
[To...] Posted July 30, 2020 Author Share Posted July 30, 2020 I was able to select both side profiles to show the difference. I really think it's really related to the original creation of the Freeform Surface. . Link to comment Share on other sites More sharing options...
[Ri...] Posted July 30, 2020 Share Posted July 30, 2020 That's a new one for me. Link to comment Share on other sites More sharing options...
