DELAY BEFORE MEASURING
Out of now where, the probe (RDS/XXT/TL1) moves to measure a feature and
stops at it's approach distance, and just sits there for about 15 seconds, WTH?
I had this happen awhile back when using GearPro.
After Calypso ran the alignment it switched to GearPro and stopped at the approach distance and would sit there for sometimes up to a minute or more.
Updating the service pack solved this for me.
Does it happen randomly or only with a certain measurement plan at a specific point?
I had something similar happen once when I did a lot of manual outlier filtering on a circle feature (the function where you manually set the angle sections to be ignored).
Type 'RAM' into the search bar in the bottom left of you screen and windows will pop up a box telling you how much memory your computer has. If its less than 16g i would contact IT and have them put an order in for some new sticks.
