Seeing the virtual system while the CMM program is running
Not really sure how to word this so I hope my question makes sense.
I created the stylus systems on the offline seat and imported the SSC files to online seat. Got it configured to all of my stylus systems and configurations, everything works great.
Is there a way to see the stylus system move across the model as it's checking the part? I can get it to work in a simulation but not when actually running the program.
Thanks.
I'm confused. I didn't know you could import SSC files into a machine configured seat of Calypso.... I've seen .it done with pcf files.
I believe the closest you can get to seeing a probe on the machine, is under CAD > CAD Model Control > Show Probe Object. This will only show a ruby and shaft.
If you're able to import a SSC to an online seat, it's certainly a software bug (in the end, without a license, it just disables that menu item - easy to screw up). And no, there's no way to show the SSC stylus during a real program run.
