[To...] Posted July 27, 2020 Share Posted July 27, 2020 Not really sure how to word this so I hope my question makes sense. I created the stylus systems on the offline seat and imported the SSC files to online seat. Got it configured to all of my stylus systems and configurations, everything works great. Is there a way to see the stylus system move across the model as it's checking the part? I can get it to work in a simulation but not when actually running the program. Thanks. Link to comment Share on other sites More sharing options...
[To...] Posted July 27, 2020 Share Posted July 27, 2020 I'm confused. I didn't know you could import SSC files into a machine configured seat of Calypso.... I've seen .it done with pcf files. I believe the closest you can get to seeing a probe on the machine, is under CAD > CAD Model Control > Show Probe Object. This will only show a ruby and shaft. Link to comment Share on other sites More sharing options...
[No...] Posted July 28, 2020 Share Posted July 28, 2020 If you're able to import a SSC to an online seat, it's certainly a software bug (in the end, without a license, it just disables that menu item - easy to screw up). And no, there's no way to show the SSC stylus during a real program run. Link to comment Share on other sites More sharing options...
