[Ri...] Posted July 23, 2020 Share Posted July 23, 2020 Hi All, I have a couple of questions that I'm sure someone on here knows: 1) Is there anyway to use a result element to pull the True Position axis deviations (the additional printout values)? 2) Is there anyway to pull the Upper/Lower Tolerance of a characteristic while inside of a result element? Many thanks as always. Link to comment Share on other sites More sharing options...
[6a...] Posted July 23, 2020 Share Posted July 23, 2020 I'm looking in to #1, but for #2: getNominal("CharacteristicName").tolerance.lowerTolerance getNominal("CharacteristicName").tolerance.upperTolerance Link to comment Share on other sites More sharing options...
[Me...] Posted July 23, 2020 Share Posted July 23, 2020 True Position (Cylinder Axis Endpoints) getActual(“Position1”).x1 getActual(“Position1”).y1 getActual(“Position1”).t1 getActual(“Position1”).x2 getActual(“Position1”).y2 getActual(“Position1”).t2 True Position (Circle) getActual(“Position1”).actual.x getActual(“Position1”).actual.y getActual(“Position1”).deviation Link to comment Share on other sites More sharing options...
[Ri...] Posted July 23, 2020 Author Share Posted July 23, 2020 Please sign in to view this quote. This is good stuff. When working with Cylinders, how you know which one to use (x1 or x2)? Link to comment Share on other sites More sharing options...
[Ri...] Posted July 23, 2020 Author Share Posted July 23, 2020 Please sign in to view this quote. Thank you, Laura. It appears that I was close, but I couldn't guess the to capitalize/not capitalize game correctly. Lol. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 23, 2020 Author Share Posted July 23, 2020 Please sign in to view this quote. So.... Z isn't an option here? I can use (I'm working with Cylinders) getActual("Position1).actual.z and I get a result, but it isn't displayed correctly. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 23, 2020 Author Share Posted July 23, 2020 OK.... Calypso is drunk. Link to comment Share on other sites More sharing options...
[Me...] Posted July 23, 2020 Share Posted July 23, 2020 Please sign in to view this quote. LOL, You'll have access to the third component if the tolerance zone is spherical. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 23, 2020 Author Share Posted July 23, 2020 Please sign in to view this quote. Do you know what is causing this? Link to comment Share on other sites More sharing options...
[Me...] Posted July 24, 2020 Share Posted July 24, 2020 Please sign in to view this quote. The position characteristic has not been computed and therefore the values are not available. You can either run the program in simulation first to compute the needed characteristics or simply assign the command to a variable in the presettings of the result element (PCM option required). I prefer the latter. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 24, 2020 Author Share Posted July 24, 2020 Please sign in to view this quote. But it was calculated. It was strange. I ended up changing the name of the characteristic, and then it worked. I was then able to change the name back to the original intent, and it stayed worked. Strange.... Link to comment Share on other sites More sharing options...
[Me...] Posted July 24, 2020 Share Posted July 24, 2020 Yup, for whatever reason the error is staying in memory. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 24, 2020 Author Share Posted July 24, 2020 Please sign in to view this quote. OK. Once again, thank you for showing me the light on these formulas. It is greatly appreciated. Link to comment Share on other sites More sharing options...
