How exactly does the caliper measurement work??
Among other things, it can supply you with both the min and max distance between
two circles. Prior to this, you had to use a result element with a formula.
I think the description says it all.
It is a powerful tool and it is my bread and butter.I don't use the other distance like Cartesian distance, point to point etc...
You can measure average, minimum and maximum values, the measurement direction should be parallel to the co ordinate axis.
