[Fl...] Posted May 14, 2020 Share Posted May 14, 2020 Hello all, I'm new to this software and I've been trying to generate a statistics report with the process capability cp, cpk. From what I know the template process protocol should do the trick but I can't seem to make it work. Here's a sample: Any tips on how to make it work? Thank you! Link to comment Share on other sites More sharing options...
[ke...] Posted May 16, 2020 Share Posted May 16, 2020 I too would like to know how to get results into the control chart and histogram in the Process Protocol report. Link to comment Share on other sites More sharing options...
[82...] Posted May 16, 2020 Share Posted May 16, 2020 Do you have a license for PiWeb Reporting Plus? You can check this by going to Extras > Settings > Miscellaneous > Licenses. Also, consider your sample size. Depending on your subgroup size for the control chart and total number of measurements, you may not be able to populate the histogram and control charts due to an insufficient n. Link to comment Share on other sites More sharing options...
[Kl...] Posted May 19, 2020 Share Posted May 19, 2020 Please read the screen Dumps 1 - 2 - 3, which decribes - Sample size - Sample size: fixed or floating based on CALYPSO 2019, Control-Chart attachend I think, the modification was integrated in CALYPSO 2017ProcessProtocol_CZIMT_680.zip1_XbS_SettingCalypso.png2_XbS_SampleDefinition.png3_XbS_Example.png Link to comment Share on other sites More sharing options...
[Gu...] Posted July 18, 2020 Share Posted July 18, 2020 For statistics, you need the PiWeb Reporting Plus license Link to comment Share on other sites More sharing options...
[CA...] Posted July 21, 2020 Share Posted July 21, 2020 CMM community Thanks for the rapid answer. Yes that PiWeb Plus the best option is, but now without such License we are using all thru C# + R-Project interface and only we are trying to accumulate raw data and make our own research. Is the only option in this case to record all data manually? Thanks a lot Link to comment Share on other sites More sharing options...
