reporting only out of tolerance characters
Hello everyone,
I want to create and export a  table which only includes red or out ot tolerance characters. Is there a way to do that through scripting ? I have surface profiles, distances and, min-max deviation labels in my inspection template.
I tried to use result_dimension.out_of_tolerance command but it does not cover all inspection elements in the template.
Many thanks,
Canset
Hello cansetm,
you don't need a script for this. You can show every inspection and filter them with view -> label -> Hide within tolerance. Then create a report page with table from this view, which will be update parametrically.
Regards,
Nanno
Hello Nanno,
Thanks for the quick response. I want to add a new column with customizing table which includes report page number for each of these elements. But when i try to do that, it  makes the same changes for each characters if the elements are the same type. How can i make individual changes for each of the elements?
Thanks,
Canset
