How To Configure Offline Seat with VAST XTR
Has anyone configured an offline seat using a VAST-XTR and the stylus simulation function?
Attached is the "Master Probe" I created in the stylus system creator. I have imported this SCC Master Probe into calypso, first followed by another stylus system. When I click on the icon to index the probe head, the stylus system is not at the bottom of the XTR sensor.
I imagine there is some offset in "Z" I need to put in the "Stylus System" tab in the CMM configuration, but what is the value?
I am using Calypso 2019 Service Pack 3 (Version 6.8.12)
MasterProbe XTR.zip
There is no need for a Z offset.
I believe that your problem lies in your MasterProbe.
You do not build a MasterProbe in SSC. There are pre-built ones in there.
Open SSC - Drop down Master probes - Select Master probe MT/VAST
MasterProbe_MT-VAST.zip
I have the same problem - it used to be fine a couple of service packs ago.
You didn't have to set any offsets.
You just imported the masterprobe and everything matched perfectly.
My guess is that its a bug.
  • 1 month later...
