[Ri...] Posted July 20, 2020 Share Posted July 20, 2020 I can't seem to find how to get the tolerances of a best fit in my report. If possible i would like to put separate tolerances on the position Z/Y en the rotation around X. it doesn't seem possible to recall these values in a formula/result element? Kind Regards, Rik Link to comment Share on other sites More sharing options...
[Is...] Posted July 20, 2020 Share Posted July 20, 2020 When you click on apply in the create alignment window will be generated a new characteristic. You can extract what you need from that characteristic: getActual("WP_BFalignment").transY getActual("WP_BFalignment").transZ getActual("WP_BFalignment").rotX Link to comment Share on other sites More sharing options...
[Ri...] Posted July 20, 2020 Author Share Posted July 20, 2020 Found it, thanks for the help. I thought i had to extract it from the feature itself. Kind regards, Rik Link to comment Share on other sites More sharing options...
