[Me...] Posted July 16, 2020 Share Posted July 16, 2020 Does anyone know how to change the default Mini-Plan file location? My default Program location is correct but for some reason the Mini-Plan default is not. Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/ Share on other sites More sharing options...
[No...] Posted July 16, 2020 Share Posted July 16, 2020 I'm not aware of a setting for the miniplan path. As far as I know, these always go to the measurement plan folder under '\runs'. Which path were you expecting? Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81600 Share on other sites More sharing options...
[Me...] Posted July 16, 2020 Author Share Posted July 16, 2020 The part of the filename that is incorrect is the PT01 network, the runs folder located in the program is fine. Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81602 Share on other sites More sharing options...
[Ch...] Posted July 16, 2020 Share Posted July 16, 2020 What is your "Name for output files"? Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81604 Share on other sites More sharing options...
[Me...] Posted July 16, 2020 Author Share Posted July 16, 2020 I don't have that turned on. Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81606 Share on other sites More sharing options...
[Cl...] Posted July 16, 2020 Share Posted July 16, 2020 What about Extras > Settings > Environment > Paths? Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81608 Share on other sites More sharing options...
[Ch...] Posted July 16, 2020 Share Posted July 16, 2020 Also, I've got this error once when IT changed a bunch of folders on the network to read-only. That could be it. Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81610 Share on other sites More sharing options...
[No...] Posted July 17, 2020 Share Posted July 17, 2020 Please sign in to view this quote. Wait a minute. Is PT01 a server name? Then a missing '\' could be the problem. Server names must begin with '\\'. This is (or was) a known bug in Calypso 2018 without service packs. If you enter the path definitions in the settings with a leading '\\', Calypso drops the first backslash and can no longer find the path. The most recent service pack should fix it. If you don't want to install a service pack, you can map a drive letter to the server address and use that instead. Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81612 Share on other sites More sharing options...
[Me...] Posted July 17, 2020 Author Share Posted July 17, 2020 Yes this is the problem, it's the actual server name. The default program location name in the Environment settings is correct, but for some reason it won't change for the Mini-Plan "Run" location. Link to comment https://qualityforum.zeiss.com/topic/15178-mini-plan-default-file-location/#findComment-81614 Share on other sites More sharing options...
