Looking for piston ring check other than CMM
Anybody in automotive use something different to measure rings like these?
The 15° and 7"18' angle and the 2.605 @ 1.5mm from edge is critical, as well as the 2.842.
We have an older Mitutoyo PH 3500 optical comparator in a different division that I know little to nothing about. They say they can't measure the rings accurately because it doesn't have side view? 164_47bd33af0bbd1f93585cb759592dc479.jpg
I would think that an optical comparator would be able to easily do this. A standard one has at least a backlight, so you should be able to see the outside shape profile as shown below.
A vision system would be my go to, as long as it can be seen.
For what it's worth, we have an OGP smart scope Flash 200. I love this thing.
The optics are some of the best. QVI in the manufacturer. I recommend anything they make!
I should've mentioned that it needs to be a non-destructive measurement and a high volume one at that.
With the optical comparator , you have to cut the ring to be able to see the edges. Also, the comparator mentioned is supposed to have sub 0.002 micron accuracy but, they say they're lucky to get .025. Like I said, I haven't used it.164_e5345b0c2c96a23fd72e95b8f5b27ae7.jpg
We have a dozen Keyence's. They are worth their weight in gold. Easy
to program, great optics, easy to use. Customer service is very good.
We use hand held blue lights, works quite nicely. I don't know the cost though. They allow you to scan the entire part and give
results quickly.
