[ge...] Posted July 12, 2020 Share Posted July 12, 2020 I have a question how I can rename the dimensions in the form of a pattern using PCM.15945364508398457718465013742356.jpg Link to comment https://qualityforum.zeiss.com/topic/15230-change-name-to-dimension/ Share on other sites More sharing options...
[Is...] Posted July 13, 2020 Share Posted July 13, 2020 Check this (for Piweb and a new feature from Calypso 2018): viewtopic.php?f=13&t=3213 Link to comment https://qualityforum.zeiss.com/topic/15230-change-name-to-dimension/#findComment-81952 Share on other sites More sharing options...
[Is...] Posted July 13, 2020 Share Posted July 13, 2020 Other alternative in compact printout is using the text element instead. Nominal= 10 UT= 0.1 LT = 0.1 Ndecimal=4 Result="" for n=1 to 8 Result=Result + "Dim at " + (360/8 * (n-1)) + " " + formatL(getActual("Dim1",n).diameter,0,Ndecimal) + " " + formatL(Nominal,0,Ndecimal) + " " + formatL(UT,0,Ndecimal) + " " + formatL(LT ,0,Ndecimal) +cr() next n Link to comment https://qualityforum.zeiss.com/topic/15230-change-name-to-dimension/#findComment-81954 Share on other sites More sharing options...
[Re...] Posted July 14, 2020 Share Posted July 14, 2020 ... or you can take the <comment> field of the characteristic and put in the names there Link to comment https://qualityforum.zeiss.com/topic/15230-change-name-to-dimension/#findComment-81956 Share on other sites More sharing options...
[ge...] Posted July 14, 2020 Author Share Posted July 14, 2020 thanks all three methods are very good Link to comment https://qualityforum.zeiss.com/topic/15230-change-name-to-dimension/#findComment-81958 Share on other sites More sharing options...
