626115-0070-020 (0.7mm M5 Stylus)
Can anyone tell me why I can do a Google Search on this stylus and get an order form to generate but I cannot find the item through the Metrology Webshop?
Aside from the obvious that it is a different URL, why can I not order this size through Zeiss's Webshop? I'd rather buy them direct than deal with another supplier. I've had rubies fall off too many times due to there not being enough glue from them.
Google Search URL: "https://mx.probes.zeiss.com/en/stylus-w ... v0bg6oa0o3" or alternatively just type in the serial # of the stylus "626115-0070-020" in a Google Search bar and it should be the 1st result.
Metrology Webshop URL: "https://shop.metrology.zeiss.com/INTERS ... fferSearch" or just type in the serial # of the stylus "626115-0070-020" in the search bar
When going through the Metrolgy Webshop, I get an automated response of an alternative stylus: "Did you mean ""626115-0050-020"? My answer is no, I did not mean "626115-0050-020". I want the stylus that I have so many projects already qualified to... 🙄 I need the 0.7mm stylus...
Description of 626115-0050-020
Stylus with thread, M5, titanium thread adapter, stepped, tungsten carbide shaft, ruby sphere, DK: 0.5, L: 20, ML: 10, DS: 1, MLE: 2.3, DSE: 0.3, DG: 11, weight: 5.5 g
Maybe it's an oversight? The webshop is just suggesting the closest match to the SKU you searched for because there's no entry at all for that part. Just email them and ask. You might be unlucky, and Zeiss decided to stop producing that stylus for whatever reason, or when they rolled out the new webshop they missed porting over stuff.
