Projection angle
I need to report the XY projection angle for two cylinders that are in the YZ work plane.
What I don't know is in which direction is the rotational error for a negative deviation?
This is a pain in the neck for me ,what I do that I increase the angle value in the nominal area so I can see which direction it move.
I think anticlockwise is positive and clockwise is negative.
